So I started getting the dreaded timing chain slap during pretty much every time I drove my 2008 LC200 w/ 195k miles. It would most often appear in the first 10 minutes of driving but eventually go away. I was tempting to dive right in a fix it "the right way" by replacing the driver side tensioner but it did seem to be a beast of a job. So after seeing some success stories online I decided to try 8 oz of seafoam in the oil. I believe it was right about 125 miles later that I stopped getting any timing chain noise, and ended up replacing the oil with full synthetic 5w30 at 300 miles after putting in the seafoam. So far so good, I'm only a couple hundred past that, but I am optimistic at this point. I might do another 8 oz of seafoam near the end of this oil change for good measure.
This LC is still relatively new to me, purchased about 6 months ago. I did also recently have significant oil sludge under the cap but pretty certainly was able to attribute that to a bad PCV, after replacing that it went away. I wonder if that contributed to the tension problem? I'm not certain. I also think it sat quite a bit with the previous owner.
I love the vehicle but every time I get underneath it, I second guess the purchase a tiny bit. I did knowingly buy a NE vehicle, but it was the first 200-series I found under 20k and jumped on it. None of the rust is concerning structurally but right around the rearmost bolt of the running board is rotted out, and the transmission cover thing is pretty bad.
Hopefully has many more miles left! I'm pretty confident it will.
