Screaming Driver Window
I know on my 80-series, the driver's window was very labored going up. I replaced the rubber runners, took apart the motor, cleaned and lubed, cleaned and lubed the regulator, cleaned the electrical contacts on the switch, and then it worked like new again.
I would try that before spending $400 on a new motor.
What did you do to clean and lube the motor? What product did you use?
I took it apart and cleaned off the "spindle" and that fixed it for like two weeks.
Also lubed everything up while I was in there.
