Hi-pinion 4.11 out of a 02 TRD Tacoma. Traded it straight up for my ARB setup. Going in the front Axle.
zebrabeefj40 said:That would be a 80 series front with the high pinion IIRC...
Nick
zebrabeefj40 said:You might want to check around about using that diff in the rear. The reverse cut ring and pinion might not hold up too well in a rear application. I might be wrong though...
Nick
AKToy said:High pinion in the front only. If you run a hp in the rear you are running on the coast side of the gearset and will greatly leverage the carrier bearings and housing; to the point of failure IMO.
