For Sale SC: Late 40 series collapsible steering column (1 Viewer)
Charleston, SC
  1. 40 Series
$250 needs some work but it’s there….
Looks like it's does not have the flange weldedat the base that bolts to the adapter plate at the fire wall? Does it have the lower shaft that makes it a collapsible column? If so is that for manual power steering?
Please see the attached diagram. The part which you are speaking of is a separate part from the collapsible column.
Just about everything in the diagram is a separate piece. Unfortunately the collapsible column was only used in a few markets. Not a high volume piece and parts are NLA. I asked about the flange to mount to the bulkhead and lower shaft that collapses into the upper shaft. The lower shaft were for manual steering or power steering. Plus a lot of small interior pieces to make it all work. Do you have the lower shaft?
