Build Saudi 84 - Tilda Bogue Service Station
Stabbed the H4/split case.
Fluid Run for the weekend. I'm headed to Missouri to pick up a 200 project for a customer that was completed by my partner in crime Jason at Ozark Overland Outfitters.
As Vice Grip Garage says, It has all the vitamins for old flat-tappet motors.
I preach Valvoline 20-50 with zinc normally fir the same reason but this stuff is 1/2 the price to be in there just for break in. It's my second fiddle
Definitely motivated to have more kids now that I know AISIN is making strollers, hopefully with lockers.
Hoping the best for this build, Nolanz Gorgarian!
I'll get you pricing :D
Sam sent the intake and exhaust to Jet Hot. Beautiful work.
Some Saudi at some point jacked up the rear most M10 1.25 head bolt. They did the front one and helicoiled it for M12 but the rear was not done. I can't get a tool in there to fix it without pulling the head so I'm just going to pray the Remflex seals it up. I got a little pressure on it with a M10 1.5 bolt. F motors don't have those at all so maybe I'll get lucky.
Putting what I can on while I wait for parts from powder
Clutch slave and master installed and bled. New brake master. Shifters back installed. Some other small stuff.
Rolling along. May crack into this front axle tomorrow and 86 the drum brakes.
Stairwell vinyl on the floor? Assume that came from the Kingdom that way? I've seen all kinds of material turned into mats over there.
Nice work on the manifolds. I assume that coating isn't supposed to rust? Have to check that out.
That floor mat has been in there for a while.
Layers
Heat protection. I approve.
Jet Hot is top of the line stuff. I have a local guy I use to Ceracote, it's pretty much the same.
