Cruiserdrew
On the way there
I highly recommend Kurt's firewall bearing. It's a very neat and clean way to immobilize the lower end of your steering column. $10 or less and it's money well spent. The easiest way to install that bearing by far is to remove the whole steering column from the truck, lightly sand the shaft, slide on the bearing, re-install. 30 minutes start to finish.
Regarding the time-If your friend has any skills at all, he'll figure it right out. I used a different kit- 4x4 Labs- but once you weld on the frame plates and the plate for the box, it practically installs itself. I nearly broke my wrist drilling the hole in the front cross member. If your hole saw binds up (which it will) be damn sure the handle of the drill is braced on something solid. My wrist hurt for a month after that little surprise.
