Safari Taller 5th Gear
Does any one have a price on the 5th gear to suit the h150
Safari Diesel POWER System
This page lists the high speed 5th gear for 2007 and on 70 series. these have the 1vd turbo v8 diesel, and h151 box. Possibly an error, but that would make it compatable with all h150/h151 boxes.
"IF" that were to be the case, I would be all over it for my HDJ!!!
But I would think Safari would list it to be compatible with other models. :frown:
Right???
New Order possible of Safari 5th gear set - Who "needs" them
Safari Diesel Extreme Duty Oil Cooler System for the 4x4 Toyota Land Cruiser 1HZ diesel engine
Ran into this.
Does anyone know if this compatible with the H55f or is it for the R151?
Fits R151F only:meh:
Greetings fellow mudders. I have been in contact with Safari systems about their 5th gear set that they "no longer carry" Here is the official scoop. Seems they only made an initial run of 50 sets and installed them all, and yet they kept them on their web site.:rolleyes:
Maybe to tempt guys like me. I really wanted a set and tried several avenues to procure one set or even a set of drawings so I could have them reproduced. Even big $ would not get the Mfg to produce me a 1-off set. However.....
Here is the big news...:grinpimp: they will do another run of 50 if I can get people to commit. This may be hard but even though I am a newbie here and I am still building my trust level with you guys, I am willing to give it a shot. I am willing to run the finances but they want 50% up front before starting production. Once they receive the deposit it will be approximately 8wks ex. works Melbourne. The MSRP is $1595 AUD. Of course I will not be paying the full retail so I am willing to give my fellow mudders a 20% discount that would be $1275 AUD each plus shipping to your location. I will try and negotiate to have Safari ship them direct to each person but these are still details down the road to work out. First I need to determine the level of interest before going ahead with this endeavour. One final note from Safari "...Toyota made a change to the R151F transmission at some stage in 2011 on the Wide-Nose HZJ70 Landcruisers, which was incompatible with our 5th gear set. We could not pinpoint which countries/regions this effected, or exactly when the change came into effect." You can check out ToyoDIY for compatibility.
So here is the deal:
1 set R151F - 5th gear set SGHZJ70C for $1275+shipping, import taxes etc.
Who is interested? Let me know:cheers:
I would think the best way to do it hand over a spare h55f and say here you go, design it to work in this. Less room for error that way. One would think that there should be a few good reputable machine shops that'd be up to the task in NA. Only kicker is one-offs or even small batches would be costly
Same goes for me if u had a taller 5th for the h55f I would be all over that
You guys could try my "plan B" if I don't get enough interest here. I used to work in machine shops and making the gears is not that hard, just have to use good material and use a reputable heat treating place. Find an old h55f tranny, find the 5th gear set and measure the clearance both while engaged and disengaged to determine how much room there will be for the bigger gears. Pull the 5th gear pair and take them to the shop and ask them how much bigger they could make them, giving them the clearance available. Have them give you a quote for 1-off, 10 sets, or more and see how many mudders want them. Best to find a shop that does custom work. I could recommend one in Kitchener, Ontario... there are several in the area that are quite capable.
An update for the H55 guys looking for OverDrive.
I have had the Mark's Overdrive gears in for a little over a month, and so far so good. They definitely are louder than stock transfer gears, but they are doing nice RPM wise on the highway.
Here are the speed in KPH/RPMs I have so far.
5th gear
100 @ 2100
90 @ 1950
80 @ 1775
4th Gear
100 @ 2450
90 @ 2250
80 @ 2050
255/85R16s. My speedo is pretty close, but I'll tighten those numbers up with the GPS;)
Sent from my ultimate time waster using IH8MUD
