SOLD Sacramento, CA - FJ80 Quad Headlight Kits & Harnesses
Sacramento, CA
  1. 80 Series
Sacramento, California United States
SOLD
For the past few months I've been working on piecing together budget-friendly quad kits that use mix of OEM and aftermarket parts. Perfect those that don't care for everything to be brand new OEM and want to build in stages. The nice part about these kits is every OEM grommet and screw clip is included which can be difficult to source.
What you get:
- Main quad headlight brackets, OEM
- Headlight buckets & retaining rings, aftermarket
- Adjuster screws, aftermarket
- Tension springs, OEM
- Grommets & screw clips, OEM
What you need:
- Headlights and/or bulbs. Tons of options out there. If you want generic 4x6 glass housings, you can get a set of 4 for $50-60 on eBay then use any H4 bulb you like
- Corner lights for non-US trucks with quads
- Chrome bezel surrounds
- Harness to convert US headlights to non-US quads *more info in pics below*
Aftermarket corner lights and bezels can had on eBay pretty cheap or places like OzeParts here: https://www.ozeparts.com.au/toyota/landcruiser/j-8-199005-199803-j80-tf5.html
PRICE: $$$ shipped per pair
Harnesses: I also offer plug-n-play harnesses that sell for $85. I can include a set for $75 if purchasing the quads. These harnesses can be built a number of different ways. Most guys choose to run a double low beam & double high beam configuration for maximum light output. With my harness, everything is literally plug in and go and no modification needed to work with the reverse polarity of the high-beam triggering used by Toyota.
