Do you still have the steering box?
i have it. Ill send you dm soonDo you still have the steering box?
Do you still have the front sway bar bushing bracket?Gold color Lx450. Axles are sold, damaged front passenger side. . Contact me for what you need.
Thanks
Sold as assembly sorryDo you still have the front sway bar bushing bracket?
Sorry, damagedDo you have the passenger side headlight assembly? I know it got wrecked on that side but figured I'd ask. Thanks!
Steering wheel needs work. I’ll check on the 6discDo you have the 6 disc (whatever it is) that goes in the center console area? I don't care if it works, just want to fill the hole that is there. I'd probably buy the whole center console if it's in good shape as well.
Edit: hows the steering wheel?
Sorry, do not.Do you have the driver side mirror?
any update on the 6disc?Steering wheel needs work. I’ll check on the 6disc
Yes, See dm.any update on the 6disc?
Maybe. I’ll check tomorrowDo you have the air amplifier located under the dash by the fuel pedal? off white box the has several plugs in the top of it.View attachment 2833621
thank youMaybe. I’ll check tomorrow
