I went by the repair shop to day to check their progress on patching up some rust. I asked them what their plan was for treating the inside of the frame where there is access to it, received blank stares and quickly realized I need another solution. I can look through various holes of rust origin and others that Toyota left in the frame and I can see and feel flaking rusty sections, surface rust, dirt, sand, etc. The tech at our disposal here is limited to spraying chemicals, sanding and welding. The chemicals available are basically heavy duty rust-resistant paints. Here is what I am thinking I should do. Based on the assumption that the frame is a hollow channel from front to back, it seems that flushing it with high-powered fresh water to remove as much dirt and debris is a crucial first step. Is this recommended and practical? Then it should be left to dry. Then I should have them either: spray as much of a chemical or rust neutralizer or paint as possible into the various nooks and crannies or block as many holes as possible and fill the frame with said chemicals, lifting it front and back as high as possible to get it to flow over as much of the frame as possible. Removing the tub is not an option out here. Based on the fact that there is already some rust inside the frame, what treatment would y'all recommend? No matter what I have to ship it in. I've used Por-15 before in brush on applications. If I go that route should I buy enough degreaser and then etcher to fill or treat the frame with each before coating with Por-15 as recommended? Is there a WaxOyl type treatment that would be more appropriate, even when applied by techs with little experience with such chemicals?
I have a little less than 2 more years out here at which time the cruiser will live in more protected climes.
I really appreciate your assistance. I am also happy to pay for a detailed set of recommendations from people that I know have the expertise but may be too busy to help me with this for free.
Best,
Rich
Best,
Rich
