rustoleum hammered finish paint (1 Viewer)
High Desert, SoCal
What kind of heat resistance does the Rustoleum hammered finish paint have? I have been searching and have not been able to find any info at all . I know most engine enamels are good up to about 500F. Does the hammered finish have any heat resistance to it?
Thanks Brad
i used the hammered finish on jakes 40...i have a can out in the shop...do you want me to go look on the label?...i used in the engine compartment but not on the engine
osagecruiser
That would great. Thanks. I need to know if it will hold up to at least 300F.
Brad
brad,
the can specifically states "do not apply to surfaces that when heated exceed 200 degrees F...i hope that helps
osagecruiser
