I couldn't find anything in a search besides info about the rusty rear heater hoses, so here is my problem:
I have been doing a series of drain/fills on my rig with distilled water after doing the prestone/garden hose flush. I probably did the drain/fill/drain at least 8 or 9 times over a week long period because I ended up doing the tap water flush twice since it looked like the drainage wasn't completely clear.
Each time I did the fill/drain, I drained both the Radiator petcock and the engine block plug (I can literally remove/install the engine block plug with my eyes closed or in the dark), and I ran the engine until the brand new OEM thermostat was open with both the front and rear heaters running.
When I collected the water after the drainings, the first 6 drains had some of the notorious gray clay looking residue that settled to the bottom of the jugs over time.
However, the last few drains (after the second tap water flush) came out orange-ish and later had a rusty colored residue that settled to the bottom of the jugs which confirmed my fear that I must have rusted something in my cooling system.
I read in e999's writeup that he wouldn't hesitate to leave distilled water in a system for a few days to ensure a thorough flush, so I must have mistakingly figured that a week wouldn't be too much.
So my question is do any of you have any guesses what the most likely source of my rust is? My rear heater lines look ok from the outside, and I just replaced the PHH w/ silicone. The PO had the HG replaced by the lexus dealer about 40K/3.5yrs ago.
I'm worried that I just fubarred a perfectly good 1FZ. Can anyone calm my fears?
