Hi all,
I currently have a Prado 150, but have just purchased a 2024 LC76 (manual, if it matters).
I don't have the new truck yet so haven't been able to do an eyes-on investigation for ideas, but I see immediately there are differences in potential options for getting cables from the roof into the cabin or engine bay.
e.g., between the Prado bonnet and wind screen there is a 3" wide plastic strip the length of the bonnet that can easily be drilled and cables run through that. On the 70 series as best I can see from photos the bonnet and body are body steel panels with just the 2-3mm clearance gape between them. No room to clearly run a cable through it without it getting impacted/bed/rubbing paint etc.
As it's a brand new car, I reeeeally don't want to be drilling holes anywhere in the body work to facilitate cables.
1) Looking to run a cable from the roof solar panel into the engine bay.
2) And from the UHF antenna on the roof to the cabin. (via the engine bay, or other route is fine)
3) Also after how one would run a cable from the roof via the rear, into the cabin.
Any help and info much appreciated.
Cheers.
Cheers.
