Rubbing with 285/70/17s on a 2.5'' lift what a i doing wrong.
I just installed the radlfo coil overs yesterday and I love the ride....Theres only one problem on full left turns, I rub against the right uca? Im probably missing a noob adjustment. What do you guys think it is?
Much appreciated.
stock
I rub on full right turn on the left reservoir with my kings....but thats because I have MORE articulation with my TC Upper control arms....
Stock UCAs may be part of the problem.
dtt255...you are rubbing your ressie right? It sounds like they are rubbing the control arm.
Actually it is because of the increase in articulation that I get from the Total Chaos arms that I am hitting the res on the drivers side.
Because of the lack of places to put the res because of the KDSS system on that side, I am stuck. I just know I can go full right turn...then pull it back a bit and I am safe.... :)
Have you gotten an alignment yet? If you're still out of whack because of the lift, it could be the root of the rubbing.
I was told to wait a week for it to settle.
Good advice. 500-1000 miles should do it. If you can flex them out on a trail that will expedite the process. I'll bet the rubbing goes away post alignment.
@Rtaylor: Do you have stock or TC UCAs? Whats your lift. Hub to fender?
Stock UCAs.
I'm out of town now but I'm about +2"
