RTH Third Row Seat Bolt Size (1 Viewer)
So my cruiser came with the third row uninstalled. I thought the bolts came with the rig, but apparently not.
Anyone know the bolt size? I am going to have to hit up Home Depot or Lowes, cause I got family here and we need the back seats stat.
I can find lots of threads on removing the seats but none with the bolt size.
Not sure what size you need, but you could try pulling one of the bolts out of the front or second row and see if that size works.
It says it in the video. I don't know the length but plan on taking mine out tonight. I think you can see in the video they are out but not sure of the scale.
So the rear seat belt anchor on the floor is a 14mm bolt that fits the seat anchor spots. Taking it to the hardware store to find the pitch. I’ll update when I find the right size pitch.
They are M10 x 1.25 pitch, about 25mm long. But yes, the head of the bolt is 14mm.
Just popped out to the garage to use my brand new metric tap and die set on the bolts and found the same info as Charlie. I can’t find a grade reference for bolts like these with just 2 hash marks on top.
note that the seatbelt bolts might be different than the seat mounting bolts. US regulations mandate some specifics on the seatbelts, I believe they are SAE thread. Whereas I’m pretty sure the seat mounts are metric.
Apologies, I was giving info for the third row seat mounting bolts, not the seat belt mounting bolts. Sorry about that.
You got it right. The OP needed just what you supplied.
no worries.. re-reading his post it did fit both spots. Might be the upper seatbelt anchor or second row is mandated to be SAE.
I just uninstalled my 2013 TLC 3rd row and have the bolts. You pay for shipping and I’ll send them to you. I believe there are 3 per side. I took the seatbelts & seat base latches out so I’ve got a handful on my workbench. PM me.
