SOLD Rowland Heights 91748, CA: $78,000 OBO - 2016 Toyota Land Cruiser 200 Series LC200 55,508 miles w/ LRA 40 Gallon Auxiliary Tank & more!
Year
2016
  1. 200 Series
Mileage
55508
Color
white
VIN: JTMCY7AJ0G4044377
Mileage: 55,508
Exterior: Blizzard Pearl [White]
Interior: Terra w/Semi-Aniline Perforated Leather-Trimmed Seating [Brown]
My family and I have decided to sell my 2016 LC200 to get a larger SUV with more cargo space and leg room i.e., Suburban or an Excursion. We purchased this Certified Pre-Owned Land Cruiser in 2018 from Capitola Toyota in San Jose, CA with 26,888 miles and was previously owned by the dealership owner’s wife. Since then, the Land Cruiser became our travel, camping and taking kids to school rig. And we spent $$$$, some elbow grease, and time, building the Land Cruiser to be even more capable :steer:. Refer to the “MOD LIST” below for information about the build.
We took good care of this rig, and the overall condition is in excellent shape. There are a couple tiny chips in the paint that’s been touched up and light brush marks on the sides that’s barely noticeable. The overall exterior paint is in great shape. The interior is clean, no smoke, no smell, some small nicks/ scruff marks on plastic door panel and on rear cargo area plastic trim. The carpet floor is clean and has always been covered with Husky’s heavy-duty floor mats since we took ownership. The leather seats are in excellent condition since we covered all seats, center consoles and front dash with Escape Gear Charcoal- Polycotton Tough Canvas right after we took ownership.
The undercarriage is clean, no mud, no scrapes/ damage, and has some cosmetic rust but nothing concerning. KDSS valve is corrosion free and protected with marine grease. Moving up, the engine compartment is clean and has no issues. All the front and rear sensors and cameras work. Both front and rear cameras have been relocated for improved viewing due to the changes made by the aftermarket front bumper and rear swing-out tire carrier.
Asking $78k OBO
Clean Carfax & Title on hand
Located in Rowland Heights, CA (borderline of LA & Orange County) ------ Feel free to message me at christianleeusmc@gmail.com
More detail info below>>>>>
Mileage: 55,508
Vehicle Title: on hand
CA DMV Registration: valid to 05/10/2024
Ownership: 2 owners *1st owner was Capitol Toyota (San Jose, CA) dealership owner’s wife from 2016-2018. 2nd owner- I purchased it on 07/2018 with 26,888 miles.
*CARFAX can be viewed in the google drive link below, under “1- 2016 LC200 sale description” folder
**More detailed photos and videos here >>> 2016 LC200_for sale - Google Drive - https://drive.google.com/drive/folders/1wZvZScOZs3IH-iSyf9DijRfSAcgC_kvZ?usp=drive_link
Maintenance History: 1st 44K was serviced at Capitol & Puente Hills Toyota for regular maintenance and I’ve done the services the last 10k. RPM Garage, well respected Toyota/ JDM 4x4 mechanics in Monrovia, CA worked on the major part of the build, and some by me (owner). All service records and a vehicle maintenance log will be provided.
Maintenance Highlight:
-TCM Calibration: Transmission Software Enhancements- completed on 03/05/2019 at Longo Toyota in El Monte, CA
-Safety Recall J15 (J05) - completed 09/06/2019 at Puente Hills Toyota in City of Industry, CA
-Limited-Service Campaign K0P- completed 01/10/2020 at Puente Hills Toyota in City of Industry, CA
-Replaced front and rear door belt moulding w/ OEM Genuine Chrome Front Rear Door Belt Moulding SET (4), purchased from Toyota parts, installed 06/20/2023 by owner.
MOD LIST (NOTE: NOT IN ANY PARTICULAR ORDER)
-BFGOODRICH
- ALL-TERRAIN T/A KO2 Load Range “E” SIZE: 285/75R17 BFG AT KO2 (5)
*4 tires install date/ mileage: 5/14/21 at 50,009 miles, installed by RPM Garage
-TOYOTA TRD- TRD Rock Warrior 17” rims “forged” (5)
-SPIDERTRAX- Wheel spacer 1.25” model: WHS023 (5) *install date/ mileage: 5/14/21 at 50,009 miles, installed by RPM Garage
-IRONMAN 4X4- FOAM CELL PRO SUSPENSION KIT- STAGE 3 *install date/ mileage: 5/14/21 at 50,009 miles, installed by: RPM Garage
This Kit Includes:
-Front Coil Springs - 2" Lift Heavy Load (110-220 lbs additional payload #TOY063C)
-Rear Coil Springs - 2" Lift Medium Plus (220-880 lbs additional payload #TOY064EA)
-45720FE - Front Coil Over - Foam Cell Pro (2)
-45796FE - Rear Shock Absorber - Foam Cell Pro (2)
-UCA056FA- Pro Forge Upper Control Arms (one pair)
-UTA200- Upper Trailing Arms (one pair)
-LTA200- Lower Trailing Arms (one pair)
-PANHARD016- Adjustable Panhard Bar (1)
The Ironman 4x4 Foam Cell Pro Features Include:
-2.8" outer body diameter
-Chrome hardened piston rod
-1/8" exterior tube wall thickness
-360 degree welded mounts
-Rebuildable design
-Threaded height adjustable strut spring seat
-Integrated bump stop (on applicable models)
-Single piece solid mounting base
-Solid one piece eye ring
-Twin Tube Construction
-Foam Cell Design
*more suspension setup info here>>> FOAM CELL PRO SUSPENSION KIT STAGE 3
-SLEE - Swaybar Relocate Kit for KDSS *install date/ mileage: 5/14/21 at 50,009 miles, installed by: RPM Garage
-AIRBAG MAN- Air Suspension Helper Kit for rear Coil Springs High-Pressure w/ Inflation Valve Bracket (located inner tailgate) *install date/ mileage: 5/14/21 at 50,009 miles, installed by: RPM Garage
-ARB- Differential Axle Breather *install date/ mileage: 5/14/21 at 50,009 miles, installed by: RPM Garage
-DOBINSONS- Diff Drop (25mm) *install date/ mileage: 9/08/21 at 52,400 miles, installed by: RPM Garage
-LONG RANGE AMERICA- LRA 40 Gallon Auxiliary Tank w/ Holley Fuel Pump, Relocated EVAP Air Filter, custom steel skid plate & LINE-X *install date/ mileage: 9/08/21 at 52,400 miles, installed by: RPM Garage
-WILCO OFFROAD- HITCHGATE SOLO XL swing out tire carrier w/ Switch Accessory Plate
-JOWETT PERFORMANCE- Filter Housing w/ EZ Oil Drain Valve w/ hose end 3/8",plug cap & safety clip *install date/ mileage: 2/18/21 at 47,474 miles, installed by: owner
-BUD BUILT- Ultimate Rock Sliders w/ Kicker & Removable full fill- dimple down platform *install date/ mileage: 3/14/20 at 49,000 miles, installed by: owner
-ARB- Safari Snorkel *install date/ mileage: 8/20/21 at 52,100 miles, installed by: owner
-IRONMAN 4x4- Premium Off Road Bumper w/ integrated Fog Lights and LED blinkers *install date/ mileage: 6/27/20 at 50,000 miles, installed by: owner
-TRAIL TAILOR- Tailgate Storage Lid *install date/ mileage: 1/20/20 at 42,700 miles, installed by: owner
-GAMIVITI- Expo++ roof rack w/ extra stepping stone plates, light tabs & gussets, sunroof cutout w/ filler, light bar drop-down cutout, fairing, powder coated *install date/ mileage: 2/28/20 at 44,020 miles, installed by: owner
-CRUISER OUTFITTERS- Rear Exit Switch w/ Handle * installed by: owner
-NATIONAL LUNA- Touch Light 18+12 LED CLEAR/RED (1) & Touch Light 18+12 LED CLEAR/Yellow (1) *located upper rear hatch * installed by: owner
-SLEE- Main battery upgrade tray w/ SLEE Battery Terminals and extensions *install date/ mileage: 10/15/21 at 53,000 miles, installed by: owner
-EAST PENN- DEKA 12V 1140A Battery #1131PMF *install date/ mileage: 10/15/21 at 53,000 miles, installed by: owner
-ESCAPE GEAR- Charcoal- Polycotton Tough Canvas covers for all seats, center console and dash cover
-HUSKYS- All weather floor mat front 2nd 3rd and cargo w/ "Land Cruiser" Decal
-DIRTY DEEDS- Resonator/ muffler delete kit *install date/ mileage: 09/01/21 installed by: Dirty Deeds
-TOYOTA- Window Visor Rain Guards (Toyota OEM)
-AIRPLEX- Bonnet Guard/ hood shield (dark tint)
-LED UPGRADES- Backup/ reverse lamp and all four door courtesy lights upgraded to Brighter LEDs
-REDARC- TOW-PRO ELITE ELECTRIC BRAKE CONTROLLER
-TREKBOXX- Rear Screen Delete Cover
-YOTAMD- YMD3 Titanium Banded= Remote Kit (2)
-NAOEVO- Chase LED Light 4" Pods: rear corners on roof rack (Amber White 6 Modes with Memory Function Spot Flood Strobe Light)
-Toyota- TRD Shift Knob
-RAM MOUNTS- Tough-Track w/ 1” (B size) Track Ball Attachment
-USB- 2 charger (QC3.0 & 2.4A) driver side
INCLUDED OEM/ Factory take-off parts & aftermarket accessories:
-OEM resonator/ muffler
-OEM Factory Front bumper
-OEM Roof/ Luggage Rack w/ Rails (complete set w/ all the nuts & bolts)
-OEM Tow hitch access body panel/ cover
-GAMIVITI- sunroof cutout filler
-ESCAPE GEAR- Charcoal- Polycotton Tough Canvas covers for all seats, center console and dash cover (note: the covers have faded over the years due to sun), but they’re still tough, clean, no rips/ damage and protects the seats, console, and the dashboard.
Some things to note:
-The parking sensor alert does get triggered when reversing due to the rear swing-out tire carrier. The rear entertainment screens have been deleted and are no longer available.
-The ESCAPE GEAR seat/ console/ dash covers and the AIRPLEX- Bonnet Guard/ hood shield will be provided uninstalled for the buyer to see the surfaces. A copy of fitment instructions will be provided.
-The engine compartment’s front-end plastic trim panel has been slightly modified with a flip open/close panel to install a kill switch for a winch. The winch is no longer available.
-The tailgate storage lid is heavier than stock, so requires a bit more flex when opening/ closing.
Nice build! Did you mention what size LRA aux tank?
Thank you! Yes it has the LONG RANGE AMERICA- LRA 40 Gallon Auxiliary Tank w/ Holley Fuel Pump, Relocated EVAP Air Filter, custom steel skid plate & LINE-X *install date/ mileage: 9/08/21 at 52,400 miles, installed by: RPM Garage
Exterior- close up (a) video~
Exterior- close up (b) video~
