This morning I had a rough start (1 hiccup). Radio memory was intact. During lunch I had the same. After work the truck had a significantly tougher time turning over. 3 or 4 hiccups before turning on. Also the radio lost its memory. The factory volt gauge was/is in the green (I don't have a multimeter currently but I have no reason to believe the gauge isn't functioning).
I mention my radio because it's wired into the first battery for 12v power. Everything is on a kill switch sans the memory power line which has a parasitic constant draw. That said, historically the truck has sat for upwards of a month without starting and never had an issue with the memory draw. The setup has functioned fine since install. I did intend on getting a battery conditioning controller once I start adding more accessories, I may need to bump that up on my to-do list.
For now I've disconnected the radio from all power sources and I'm currently letting the truck ideal at 1500rpm to recharge the batteries (just in case I'm experiencing mismatching charges on my batteries and/or my gauge is malfunctioning).
Im worried it may be my starter going out on me, but the memory on the radio losing power leads me to believe that's not the case. Other ideas maybe a relay or fuse that may have been toasted by the shippers of my vehicle causing my batteries not to get a charge, possible? Any ideas on what/how to trouble shoot. I'm not well versed in the electrical side of things. Thank you in advance.
