I added an OME 40mm lift kit, medium duty, and was amazed at the improvement of handling and how it smooths out larger bumps, both on and off road. Body roll in corners was also noticably reduced. It does feel rather harsh on roads with a lot of small bumps/pot holes with only one or two people in the car. If there are four or five, the ride smooths right out and is fantastic.
As it is a daily driver, I put a couple bags of cement in the back wrapped in plastic bags, (96 kg, 211 lbs). This made a huge difference in daily ride satisfaction, but is occasionally inconvenient when I need to put larger items in the back.
Has anyone found a better solution for this? If there was a product that easily added weight by adding a 1" cover to cargo floor area, do you think that would be worth buying?
Here are the installed kit details:
Coil Springs (Front) (2884 x 1 pair)
Coil Springs (Rear) (2889 x 1 pair)
Nitrocharger Sport Strut (90010 x 2)
Nitrocharger Sport Shock (Rear) (60080 x 2)
I do have an Ironman Steel Bullbar on the front
