Ok...so we got my wife's 91 (162k) put back together after a head gasket job and now we can't seem to get it running right...
It keeps throwing a code 71 (EGR System) and there is a rough idle once you've gotten it up to speed and brought it back down a couple of times (like the 2nd or so stop sign it starts to rumble, drop below 600, sometimes all the way down to 400).
here's a list of what's new:
• Fuel Pump w/ Fuel Sock
• Fuel Filter
• Head Gasket
• All Vacuum Lines
• Cap
• Rotor
• Plugs
• Wires
• Intake Hoses
• Rebuilt Power Steering Pump
• Power Steering High Pressure Line
• Low Pressure Return Lines
• EGR Valve
• EGR Modulator
• PCV Valve & Grommet
• Stock Height Replacement 1” Lift
• Front Bumper & Winch
• 31x1050x15 Goodyear Wrangler Duratrac Tires
• Alternator Belt
• AC Belt
• Water Pump Belt
• Radiator cap
Also, the radiator did have to come out and have the bottom spout fixed, and since we've put it back in there's a coolant issue now, too...it seems to be losing 1/4 gallon of coolant per every other driving session, but there's no leaks underneath it or on any hoses/tubes when parked...
I'm really at my wits end here...when my wife drives it to work she puts it in neutral or park at lights so that it won't idle as rough...I'm nervous to let her drive it because i don't want her to get stranded...
any thoughts as to the code 71?
any thoughts as to the rough idle?
any thoughts as to the magical disappearing coolant issue?
thanks all...
dan
i've posted this to the 3fe board too, but was wondering if people around here had any other suggestions as well...
• Fuel Filter
• Head Gasket
• All Vacuum Lines
• Cap
• Rotor
• Plugs
• Wires
• Intake Hoses
• EGR Valve
• EGR Modulator
• Alternator Belt
• AC Belt
• Water Pump Belt
• Radiator cap
thanks all...
dan
