I'm a new owner of a '99 LC (less than one month of ownership). We had moderate rain here last night, and this morning when I drove it, I had about a third of a cup of water pouring out of the front center ceiling dome light (the one between the two sun visors). Needless to say, I was quite discouraged since I've just had to replace a failed starter last week and it felt like if it's not one thing, it's another. However, after searching this forum and reading posts about leaks caused by the sunroof drains, I tested them and found the right drain plugged. Tomorrow I will go to a hardware store to get some wires to clear the drain as suggested to see if that solves the problem.
I also want to take down the front center ceiling light assembly to dry it to make sure that there isn't any amount of standing water still collected/pool in the switches or over the electrical contacts. Can someone advise how I can take this light assembly off of the headliner? I saw only one screw inside the remote transceiver compartment and unscrewed it but the assembly still feel pretty tightly mounted to the headliner. I didn't want to force it down and risk damaging it before I ask people in this forum if there is anything else I'm supposed to unscrew or loosen.
Also, in one of the posts, a forum member mentioned that the sunroof drain opens down to the windshield area. Can someone point me to exactly where? Is this lower opening visible so when I thread a wire through to clear it, I can see it coming out of the drain opening and know that I've threaded it through the entire length of the drain?
This brings me to the next question. Are there any other drains in the vehicle that I should run the wires through to clear before the raining season gets into full force?
Thanks again for your help. Without this forum, I wouldn't have known to test the sunroof drains.
