Roof Clocks
Hello all,
Have just acquired a set of roof clocks which previously found home in an imported japenese model.
As I have a UK model it is only pre-wired for the internal light / sunroof controls in the roof area. The roof clock assembly from the japanese vehicle has built in altimeter / compass which have seperate electrcial connections and are not present in my roof area.
Does anyone have a wiring diagram for these?
Cheers
Hello all,
Cheers
Does your console have a sub-tank fuel gauge?
Do a search on this. I saw a writeup on the wiring not long ago.
PITA but you can find it and get it done.
Good luck.
Pics please.
Karl
i recently wired up my console. It's really easy to feed the wires up there. Use a straight coat hanger to fish the wire between the headliner and the sheet metal , then bring it doen the A pillar (by removing the plastic garnish) then through the dash to the kick panel. It only takes a few minutes. I had to cut my headliner a bit make the overhead console fit. Search for elmariachi's sub tank write up. there are lots of good pics and wiring descriptions.
