Hey Team,
1989 Toyota Pickup 22RE 4WD IFS - 224k miles
My truck started knocking the other day. I checked Valve Lash and it was all good, I set to .008 and .012. I did the spark plug boot removal test and the knock stopped when removing the spark plug boot to cylinder #4. I dropped the oil pan and was able to replicate the knock from rod assembly #4. See knock video here. I ordered a micrometer set, dial bore gauge, and plastigauge along with standard size connecting rod bearings from Yotashop.com. Have to learn how to use those tools via Youtube - if anyone has tips/tricks input is gladly accepted. Going to see if I can measure and make sure the standard size connecting rod bearing will fit and resolve cylinder 4 knock.
My question is:
Should I replace all 4 connecting rod bearings while I have access to the crank and rods via dropped oil pan? None of the other rods have side to side play. I'd rather not mess with too much I would imagine it's worth replacing all four while I can easily.
Additional Question:
How much cylinder blow-by noise/hissing would be considered normal?
See blow-by hissing video here.
As I spin the motor, I can hear A LOT of air hissing by the pistons. A couple months ago, I did a compression test and cylinder #3 was about 9psi lower than the rest at about 153 - (cylinders 1, 2, and 4 were about 162). I did not do another compression test since the knock developed nor before I dropped the oil pan to check the rods.
Any input is appreciated.
My question is:
