Ring Gear Pattern
Frisco, CO
Input on this ring gear pattern.
Had some trouble with the dried out paint. Tried some solvent, and another go with some oil drops.
Could probably move the pinion in a few 1000ths, but I don't have any shims under .009.
thin the paint with some oil.
pattern looks like it could be a little deeper.
I'll add a little more oil to the mix and try again.
Need to go through my shims to see if I can get a shim stack to drop just a tad.
It looks close, what is your backlash? How about pinion preload? I usually get readings in three different spots with at least 5 teeth.
BL @ .008"
PL @ 10-12 in/lb
I ran another pass and got the same results. I reached out to Ken (Zuk) and he recommended reducing the shim stack by .003"
