Rewiring OEM Instrument Cluster 75 FJ40 (5 Viewers)
Have installed the 20 circuit Painless harness. Just finished up today. I saw where someone was looking for instructions on wiring the OEM instrument cluster. I'll describe what I did, and hopefully it will be enough to be helpful even if you didn't do exactly as I did.
1. I took the instrument cluster out, and removed the 12 pin circular connector, and the two wires to the ammeter.
2. I took each of the lamps out of the instrument cluster and used very fine emery paper to clean the copper pads as mine had corroded up pretty well. Likewise I removed the nouts on the instruments (fuel guage, temp guage and oil guage. I cleaned the copper pads on these as well. Finally, I cleaned each of the 12 pins with emery paper wher ethe circular connector goes.
3. I cut the wires off the old harness where the round connector was, leaving about 4 inches of wire. (I had put all new vintage connectors everywhere else on the vehicle, but couldn't find this round connector so had to spilce the old connector wires onto the new wires.
4. I in-line twisted each wire to the new one, soldered, and slid weatherproof heatshrink over each solder joint to insulate them.
5. The Painless harness does not explicitely provide a switched power wire to the instrument cluster, nor does it provide a ground. You'll need both.
6. Here'e the wiring:
Pin -- Old color -- New Color -- Function
1 -- White/Black -- Black -- Ground
2 -- Yellow/Black -- Lt Blue/Black #722 -- Oil Sender
3 -- not used
4 -- Blue/Red -- Red/Blk -- Battery + (switched)
5 -- Yellow/Red -- Pink #739 -- Fuel Sender
6 -- Yellow/Green -- Lt Green #721 -- Temp Sender
7 -- Red/Yellow -- Green #736 -- Hi Beam Indicator
8 -- Blue/White -- (I didn't used) -- Veh Speed sensor to emission box
9 -- Green/Yellow -- Dk blue #738 -- Right turn indicator
10 -- not used
11 -- Green/Black -- Lt Blu #737 -- Left turn indicator
12 -- Red/Black -- Brown #730 -- Instr Panel Light
All seems to work fine.
This really helped me when I used the Kwik Wire harness
