Still imagining a rally/desert racing style springover front and rear on an fj60...on a control arm setup, like in a Dodge Ram, the 4 control arms (2 and 2) are behind the axle, I assume for protection.
Just as a reverse shackle helps rolling over obstacles a la wheelbarrow, wouldn't reversing the control arms "pulling" the axle provide a better roll than control arms "pushing" on the axle?
I figure I could find some links and mounts off a wrecked Dodge and adapt them to my axle without having to guess my own engineering. Setting them up in the front of the axle isn't even so much of a priority, but I thought it was an interesting question to throw out there. So here are my main questions about putting control arms in front of the axle:
1. Is this just a bad idea because it's too much crap up front to break?
2. Is this a bad idea because you would need a high steer? (I'm assuming high steers are bad at rally speeds? Correct me if I'm wrong)
3. Is this a bad idea because steering is affected in some geometric way I haven't considered?
4. Is this a great idea and I'm just smarter than every engineer who has ever worked on the front half of an automobile?
