- Thread starter
- #41
This is the kind of feedback i was looking for...i am going to give the OEM rebuild a try today, if it doesn't work i have another option.
Snake- was your OEM that you replaced older...from what i am hearing from Tools and others that the OEM might be as good if not better than the Blue if it has a high enough viscosity oil in it?
Thanks.
I just completed a thorough shakedown of my landtank modded blue clutch. Before the clutch, on hot days, climing steep freeway hills in 100 degree desert heat I was getting up to 225 degrees. Now I rarely break 200, with 209 being the very hottest I've been able to get it. I'm satisfied. I'm puttin a pusher on just to keep the AC temps down a little.
Thanks.
Everything as far as temp and drivability was exactly the same after I replaced the OEM with a blue clutch
The only change I noticed was the roar on startup (OEM didn't have it)
