RET2
Is it possible to recalibrate the ambient temp display?
Pretty normal.Where is the sensor located?
I was just in big bend and while parked in the sun it was showing 109F. Started driving and that lowered to 103 or so..
Pretty normal.
109 in May?
That should be the cabin temp sensor for the front AC. I took RET2's question to mean the readout for outside temp, though could have been wrong.I'm wondering if it is the sensor that is in the kick panel by the driver right knee - the one with the white corrugated tube extending out the back?
Not sure if this might be helpful:
Dashboard
Dashboard cable
EA2
82824-60500 82824-60530
Dashboard Wire & Engine Compartment Lead Wire (Dash Side Panel LH)
I have questioned the out outside temp read out for a while now and have inspected the connection. I did not ck resistance. If I was messing with the right one it is located behind the grill attached to the vertical center support.
Where is it though?
Thank you!It says you have to remove the bumper cover, but you can likely reach it from behind the grille.
