Hi all, I am talking my beater 4runner to college at the end of the month and I am concerned about the amount of oil its burning. Has been burning for awhile, but the problem seems to be growing faster and faster. Its got 190,000 miles on it and the body is trashed. Which is a good thing, because my school is in flint michigan, not the place where you want to have a nice truck.
I am not looking for a full rebuild, I am shure it needs it. The engine runs great, no knocking sounds at all, even after sitting in the cold for weeks. So the bearings are probally ok.
From my understanding I can pull the heads and take the rod/piston out the top, then tape over all holes and hone the cylinders with one of those things that goes on a drill, to break the glaze, then scuff with sand paper, not shure on the grit? Probally 180-240?? Then put the cleanded rod/piston back in with new rings and call it good.
From your experience with engines what wears more, the rings or cyl walls. I expect tje rings to almost be gone, how much will the bores have opened up? Will the bottom still be circular? I guess I could take the block out and get it bored, but if I was going to do that I would want a 5vz-fe in there with the s/c.
thanks for any help.
