Thanks @EasternYeti, these look great. Assuming the correct hardware is used and the brackets are intact, where is finesse involved on this install? I'll probably need to fab some brackets myself since mine are mostly gone but I'm almost certainly going to use these mud flaps.
Thanks!!
If you wish to use larger stainless steel bolts like I did, you’ll need to be prepared to drill out larger holes, which might be unnerving for some. Once drilled the holes will need to be prepped and painted to prevent rust.
additionally, you’ll need to pay close attention to detail. Measure twice, and cut once when making bolt holes in the mud flaps - that way they stick out/drop the same amount on each side....then there’s the consideration of making all 4 match.
Not brain surgery, just a lot of patience and measuring - end result is worth it IMHO
For 30.00 or so Rokblokz’s will send you some brackets they ship with the early Tacoma / T100 kits that might make life easier
