Replaced front U-joints on my 2000 Cruiser. Checked the FSM for U-joints and noticed that both front and rear driveshafts are in backwards. The slip joints are at transfer case end, but should be at axle end. Only had the truck about 6 months, doesn't look like any major service had been done in past. Anyone know if any got out of the factory this way? Looked at some photos on this forum and only see them in the right way.
Anyone know of issues flipping them back the right way in terms of increased wear?
How to replace U-joints:
Did not have the special tools the FSM calls for to change U-joints. Made do with The Basic Toyota Fixture (BTF) - a brass bar and hammer. Darn Cruiser should come these and mounting brackets to hold them.
Wouldn't hurt to hit joint with a penetration spray
Note positions of yokes and grease jerks so you can get it back the same way, MAKE SURE you have good reference points because once its apart, if you forgot to mark something, well...
Position joint on a pair of wood blocks, or a piece of wood with a hole a little larger than bearing case, so bearing case goes between blocks or through the hole.
Drive top bearing of spider down with the BTF so bearing case groove shows on outside of yoke.
When it is far enough you can twist the bearing case. Don't drive too far, hard to get the top bearing case started back in hole to it drive out. Note: The bearing case is a smaller diameter on the spider side of the groove.
Pull out bearing case.
Flip joint over on block of wood.
Drive the exposed spider shaft using the BTF back the other way to drive the opposite bearing case out.
When it is far enough you can twist the bearing case and pull it out. The spider can now be removed from the yoke.
Repeat for the other side of spider.
Position spider in one of the yokes (based on reference marks you made earlier) insert the bearing caps in top and bottom of yoke getting them lined up on spider shafts. With bottom on block of wood using BTF carefully drive caps. Alternate driving top and bottom caps.
You want to position the spider so it is centered. Install snap rings. Use feeler gauge to check gap at snap ring. If it is outside tolerance different thickness snap rings are available from Toyota.
Repeat for the other yoke.
