Replacing clutch in 92 Camry
Status
Not open for further replies.
Fort Langley, BC
My 1992 Camry V6 finally needs a new clutch (@ 250K+ miles). I'm gonna have this done by a shop and I want to make sure that since we are in there, all important parts are being replaced. What should be replaced if I'm gonna keep the car for another 5 years:
- pressure plate ?
- throwout bearing ?
- release fork?
- diaphragm spring ?
- clutch disk?
- not even sure what else is in there needing replacement
What's weird is that it's not failing the usual way of slipping, it's not disenaging correctly. It's not the master/slave as that's been replaced just a little while ago (unless the pair failed quickly).
I'm sure the shop will want to replace what's worn out, I'm just making sure that I have as much knowledge as possible and not have revisit this a year from now....
I'm gonna price shop this job at the dealer and an independent shop.
Thanks in advance guys for any advice.
Riley
disc, pressure plate, throwout bearing, pilot bearing/bushing. That should be it.
What about resurfacing the flywheel?
whodat said:
Sorry, Couldn't find the Tech Camry forum on MUD..... :grinpimp:
Thanks I didn't know that got added sometime in the past year or so....
Probably worth spending some time with...
Status
