Hi all,
About to replace new rotors and wheel bearings and started to think about replacing front and rear shocks at the same time. It's a 2000 Land Cruiser with 100,000 miles, shocks have never been replaced and no other suspension work has been performed. Bumpy roads are a bit sloppy with the current stock shocks as I assume they're pretty worn.
This Land Cruiser is going to primarily be a highway road / snow trip car / minor off road, and won't see any significant off road use, so I don't currently need a lift. I won't be adding any armor / bumpers / additional weight at the moment. I prefer to keep a stock like ride quality, not too stiff. I would be ok with a 0-1 inch increase. I'd also like them to be long lasting. Currently running 285/75/16 Michelin LTX MS/2s.
So far, after researching my best options for maintaining a near stock ride height seem to be:
- Bilstein 4600 HD - heard these are the stiffest of the three options
- Fox 2.0 - heard these are in the middle, and a good option for ride quality while being an upgrade from OEM
- OEM Toyota - Are these Tokicos? Or something else? I assume these are good for my application, but want to see if there is a better option
Few questions:
- Anyone have experience with any of these three and what's your opinion?
- Any other suggestions?
- Assume these wouldn't need custom valving on a stock vehicle?
- Where would you order from?
- Additional parts needed at the same time? (bushings, cushion, retainer or reuse?)
- Springs? Any reason to change or are these typically not replaced?
Thanks in advance.
Few questions:
Thanks in advance.
