Its an Orbital Extreme they make a few flavors, this is the bling bling model $130. the Optima red tops are OK as well, I just don't like the yellow tops. If you want some real bling........the Odyssey are great, got a pair in my fj40, but they are not cheap and I would say not needed unless you need a small powerfull battery for a uniigue placement, which I had in my fj40, I used 2 1200MJT's in the stock tray.....very happy but they are $150 each.
cables, I make my own with 1/0 welding cable.
yes stuffs been moved around, I added 2 batts, replaced stock tray(and added 2nd) with stainless trays($50 each) also moved the overflow bottle by using a OEM hj60 mount, added a 200 amp Mean Green alt. also a Wrangler dual battery switching set up. there is also a 200 amp fusible link going from the alt to the batteries. Also an ARB compressor. Not one hole was drilled everying mounts up to a stock location or existing un-used hole. Same set up(besides the alt) will work in a fj62, some things might be a bit different but real close.
