Replace what parts?
Vidalia,Ga
I am in the process of replacing a leaking rear main seal. I am probably going to replace the clutch, pressure plate, pilot and throw out bearing. Also resurface the flywheel. Are there any other parts that should be replaced regardless of their condition or age? Or should they be replaced regardless? Thanks <><
I always replace the pressure plate bolts with new OEM one's.
Good time to replace your input seal on your transmission, and check the boot on your clutch fork too.
