Removing window motor or regulator assembly when window is stuck closed
Juneau, AK
Just like the title says. I tried searching with no luck. It's the right rear window, so not real critical but it'd be nice to have it working.
I've determined power is getting to the motor so my assumption is that it's dead.
Accessing the three screws holding the motor to the regulator seems impossible because part of the contraption is blocking the top screw.
Thanks for any advice.
The thread above was quite helpful. It is not necessary to unbolt regulator from window with the back windows, but it is on the front windows.
It's impossible to remove the window motor from the regulator with the window up all the way.
It's a done deal now-sort of. New motor works, window goes down fine but gets stuck in one spot going up. That's probably what killed the motor originally.
