I'm planning on upgrading the leaf springs on my trailer from a vintage 32" 5 leaf set with a load rating of useless, to a modern set of 24" with a load rating of 3000lbs. These springs are taller (larger distance from axle to frame) and I'm adding some 2" box section to the underside of the frame for strength, so I'm looking to try and reduce the height a bit to keep more weight on the axle and not on the hitch. The hitch is only rated for 1500lbs so the springs are twice as heavy as I actually need, and I figure will probably result in a pretty firm ride if they are used at most half load (and rarely that much). The axle is already over the springs, so there's no space to be achieved there.
So I'm looking at removing one of the springs and have a few brief questions:
1. Is it safe to do so? I'm assuming it'll still be more than strong enough with a spring removed, but it doesn't hurt to check!
2. What spring should I remove? I'm assuming the shorter middle spring (2nd shortest, or 3rd from the top) as the smallest is an overload leaf, and removing the next one up will have the least effect on strength.
3. How do I go about it? Just unbolt, remove the clips, take the leaf out and re-assemble?
Thanks in advance!
Thanks in advance!
