Removed stick/ Lost gearing
I removed the stick on a 72 three speed transmission. Installation should be the reverse of removal however the only workable gear I can find is Reverse. And the stick is now in the first gear position. Any idea what a did wrong?
the shift fingers in the shift tower were not lined up properly before jamming the cane back in, remove and inspect.....it's nothing serious.
X2
Yep. :banana:
Thanks! That was bang on. If anyone finds themselves in the same pickle here is what I did: use a stout screw driver to move the shift iner-lock plate. Use the screw driver to flick the fingers up or down til the gaps align. That should be neutral.
