Removed H and put in a 2H..Any help!:?
I recently acquired a 2h to replace an H with a cracked block. The problem I ran into so far is the 2h didn't come with front block mounts and exhaust manifold.. My h mounts won't work for the 2h and obviously the exh. manifold won't work. Does anyone know of any other issues I may run into with this swap???? Looking for mounts and exhaust manifold so far...I'll post in parts........Please help! Thanks.
Hi, Go through my rebuild, should answer a few questions.
Well, I my first thought is clutch issues if you're planning on reusing the "H" clutch, but I haven't looked into it at all so it might be fine. I know there is more hp and torgue in the 2h so I wouldn't be shocked if the clutch was different.....My next thought would be what else is missing off the engine? Having an h engine myself, I have had little luck with compatibility between h and 2h... is the rest of it there?
