Want to add remote start to my 98', but would like to have 1 keyfob
any ideas?
Thanks all!
any ideas?Thanks all!
any ideas?Want to add remote start to my 98', but would like to have 1 keyfobany ideas?
Thanks all!
Had an Autopage system on my 80 - loved it. Off-roaded it plenty with no issues. Had I been smarter I would have installed one on my 100 rather than spending $80 for another OEM key with button head.
Sneaky on zip tying the key, I didn't think about how you'd defeat the transponder. I guess you could make it safe and cut the key part off, just leave the head of the key under there.
Check out autopage systems (Auto Page Vehicle Security Alarm Systems - Car Alarms, Remote Starters, Keyless Entry. )I have a remote start on my 98 - one remote - works the locks and starter. You do have to zip tie a key under the dash so the remote start will work.
Sounds like placing a key under the dash, albeit well hidden, is a bad idea.
I've got a remote start and there was no need to install a key under the dash. My guess is if it gets installed by someone with installation experience, it's not necessary to strap a key. Sounds like placing a key under the dash, albeit well hidden, is a bad idea.
Security transponder's got to get a signal from somewhere if you're not there and hit the remote start, having a key hidden is a great idea. And provides emergency access to a key if the need should arise.
And when utah62 says WC's Master Tech, he means a real Toyota certified Master Tech, so I'd hope he knows what he's doing.
If the truck is running and the brake pedal is depressed to shift into gear, if the key isn't in the ignition with transponder, the truck shuts off. Of course, if someone wants to steal the truck and they come across the hidden key, makes things real easy.
well now that its posted on the internet that utahfj62's 100 has a key in it at all time, i wonder what will happen?![]()
infact TM is teaching a class on proper shooting techniques this week....I have the same setup. No key in ignition and you depress the brake pedal - the truck shuts down.
If someone can find the key under the dash - and make it work - they can have the truck. I never said it was a cut key under the dash - it is a blank - not cut.
