Remote and lock button not working
New York
Update: the problem below now occurs on occasion. Ugh
Remote lock and and door lock button not working, unlock works and I can hear all the actuators unlocking. Batteries have been changed and the second remote is not in the car.
all buttons on remotes work on both remotes. Car won’t lock with remotes, outside door button or even the inside lock button with the car running.
If I manually lock the car and then press the lock button on the remote I get the audible lock beep. This is driving me nuts.
2011 145,000 miles.
What am I over looking? thoughts?
Clarification question: the remote is not working for any buttons or just the lock button? Also, the unlock/lock button in the door handle isn’t working?
Have you tried the second remote? Do all buttons work? If yes, then the issue wouldn’t be with the vehicle but likely the first remote.
I updated the post, just drive 150 miles and now it locks
Anyone
Do you get any sort of noise, the constant beep when trying to lock? Also I see you mention a line of when car is running. The key or button on outside of door will not work when the car is running to lock or unlock the car. Your interior button to lock all doors should work...
Are you able to lock all doors by using the physical key in the driver door?
Wanted to chime in here as I am experiencing the exact same issue. Over the last week my car will not lock when I touch the lock button on any door handle, or with the lock button on the key fob. Won’t lock with the interior lock button as well. I might add that the speed sensing auto-lock also doesn’t immediately work, but occasionally after driving for a while I’ll hear the doors lock. Very strange and intermittent. Forgot to add this is a 2010 LC, 234k on the clock. Hope someone has an idea here, very frustrating to say the least.
Starting with something simple, change battery in Fob, that's all I have
