Relay location for switching between the dual diesel tanks 75 series 1993
BC Canada
Hello, I've replaced the two solenoids and now wanting to check the relay as per other threads.
I can't find it on the Troopy and need some help please.
When I turn the ignition on the two soleniods make a sound but when I press the rear tank button nothing happens. It's stuck on the rear tank.
The other threads show the location of a different 70 series.
Cheers.
Just some more info, looks like the power is stuck on for the rear tank, has anyone had a switch fail? The little LED light goes on and off but power stays on through to the solenoids.
Yeah, I was only asking as on another thread a 79 series had a relay associated with it. Doesn't seems to be the car here.
I believe now it's just the push button switch which has failed.
I'm going to try and see if there's someone around town that will have a go at fixing it or I'll attempt to put another switch in myself.
Have you looked at the schematic for the vehicle? There is no relay.
Found this, it's the switch.
