Redoing the brakes with all AN fittings
If you currently have 9mm fittings, you're going to need to find 9mm to 10mm Adapters or later model elbows and T fittings if you're converting to 10mm. The classified section will help in finding what you need. I think the later model master and calipers will be 10mm along with later model soft lines. If your reusing the old stk wheel cylinders for 9mm fittings will need Adapters for these too or update to newer wheel cylinders.
My 40 is a 75 so everything was 10mm already.
good call out, thank you!
