Dropped off at his shop this afternoon, he had it outside running for 3/4 of an hour and still smoked.Run it for a while, run it up to temperature... carefully. The smoke could be residual stuff in the exhaust system.
The pump will self-time as long at the marks on the pump are lined up with the marks casing on the engine.
~John
Does it start and run smoothly ,or does it cough and splutter for a while?
To what extent did the rebuild go?
The engine runs smooth, just lots of grey black smokeThis sounds like a timing issue.
There are all kinds of other reasons for smoke - other than the smoke, how is the power and response of the engine?
~John
Did the correct thickness of head gasket get used (it needs to be measured via piston protrusion).
~John
I thought a lot of people put the thickest type on just to be sure.
I would not have thought the compression would be affected by a few thou if thats whats being suggested.![]()
The F grade head gasket is the default one... but why would Toyota go to the trouble of making 4 sizes (factory) and 3 sizes for repairs if it wasn't an issue.
I've seen too many smoking LJ78s to not think there is something to this theory.
~John
The smoking issue is very common with these engines - being the 2LT-E version. The smoke is incomplete combustion of diesel, from what I can tell. It is there when cold, and not so bad when hot.
~John
The difference min to max between the thin (B) head gasket and the thick (F) head gasket is 0.3mm. Applying V=PiR^2H you get a difference of 1.99 CC between the two gaskets. It doesn't seem like much.
The only proof is take an engine that was a known good runner with no smoke before the head was replaced using an F gasket, and then pull it apart and install the correct (B) gasket and see if the smoking issue clears up for the most part.
Waiting to find out...
~John
