Rear Wiper Spray Line Leak
ntsaint
Don't Assume I Know The Basics...
Louisiana
So I go to turn on the rear wiper spray today and clean my back window, and I get a steady stream of fluid spraying onto my left foot!
After further inspection, it appears that the line that feeds the rear wiper runs from the reservoir under the hood, through the firewall by the driver side fuse block, then on toward the back.
The line appears to be leaking where it goes through the firewall. I understand what I have to do here, but don't really know where to start.
Anyone run into this before??
Sent from my iPhone using IH8MUD
This was a rather simple fix, but a huge pain in the as* because of the tight space. Had no idea the fluid line ran through the cabin...
Pics? Mine does not work and have not noticed water on foot but wonder where it is failing...guess I need to disconnect at pump and see if it works and then go through line all the way back.
Same here. I guess I should get a helper and listen for the leak.
