NOFor $20 how can you go wrong especially if you have a broken gear to start with??????? I personally haven't seen these 3D printed gears butr have seen the brass gears that were available for a short time and have installed several of the OEM gears.
Thanks. You made my morning.Is there a warranty?
Can you reach the L clips that hold the window and window channel to the regulator arms? Best bet is to push/pull those with a long screwdriver so the windo can be removed completely. You may need to pull the window felt to have enough space for the channel to fit through the opening though.Anyone have any reasonable remedies to get my window back out to work on this mess? I have disassembled the wiring AGAIN so after pondering I can't figure an easy way out here.
