I have a question reguarding a rear propeller mount. I noticed when pulling it apart, that the bolts that go thru the rubber donuts/ angle peices on frame were angled like the frame was to wide for the propeller mount. I got some 1/4 plate aprox 5" x 8" to use as a spacer between the frame and the angle pieces, hopefully allowing the bolts to drop straight in, instead of seemingly being in a bind. My question is- should I weld the plates AND angle pieces in, OR weld the angled pieces to the flat plates, then bolt the plates to the inside frame walls. Or, is this a none issue? On another note, I went thru the search looking for info on the correct way to install the seal between the trans/tc. It looked to be a 50-50 deal on which way it went in based on everyones experiance. I think it was Igge who stated that the seal went in " spring side towards the trans " due to her having done it both ways and this one working better. I hope so, as thats the way mine went in. As usual, any/all advice appreciated as this is kinda like on the job training trying to figure what the PO has done. Thanks, Al
