Rear Storage Cubby Pouches/Rear Side Panel Molle Panels
Maryland
Has anyone found any sort of zip up or similar pouches that fit into the side storage cubbies back in the 3rd row/cargo area? While on that note, does anyone make molle panels that fit on the rear storage area sides panels (with the 3rd row removed). I've seen the windows molle panels but looking for something that mounts below the window on the plastic side panel.
Hazard4 makes a panel for a bag which has webbing on one side and loop material on the other. I no longer have the bag, but I kept the panel and use it to attach pouches on the front side of my drivers’ seat.
The Hazard4 panel is spendy, in my opinion, but I’ll wager there are similar flat panels available for less.
Not sure if it's the exact spot you're looking for, but if you get the Kaon Shelf (which you should) they make a Molle panel addon for the rear side windows that works together with it.
Not doing shelves/drawers/anything that takes up any floor space in the cargo area as it's not gonna be an "overlander" build. Just looking to keep some various day to day things like bungee's/tie downs/misc tools out of the way so I'm not having to move stuff around every time we are putting something larger in the back.
The shelf is overhead, does not affect rear visibility at all. Only impactful if you use 3rd row (headroom). Otherwise, doesn't impact floor space etc at all, and could be used for storing odds and ends. I use mine for many of those random things, jackets, towels etc.
You can install without side panels and just do shelf if you want too. Keep in mind prices are Australian so a bit less with conversion to USD
I just installed the Kaon shelf with full sides today.
Looks nice! How was the sides installation?
Very easy - directions were pretty clear. Only thing I’d add is be careful when installing the captive nuts. I ended up adding some gorilla glue to them because I was too nervous about one slipping and then I’d have to take apart the interior to try to retrieve it. Took about 1.5 hours start to finish
Looks amazing…. Just picked up a 2020 LC200 Heritage today and am OVER THE MOON! Moving from the 4Runner platform so all sorts of new stuff to learn… And buy! Where did you get your Kaon gear. I had side molle panels in my 4Runner and they were amazing for organization and this looks like it takes it up a level.
You can buy direct, just remember prices are in Australian dollars before you get a heart attack.
I like it a lot - well made and super useful. Install was pretty straightforward.
Congrats on the new ride! This is my favorite LC platform- enjoy!
