What size is the top nut on the rear shocks?
Ummmm did you grab a bunch of sockets and try some?![]()
was going to say 19mm but you might be right. Have changed to radflos and they may be different than stock. I had to replace one of my top nuts and bushes recently because of damage caused by loose nut. I can confirm that getting at the LHS rear shock nut is a real pain, not least because of the angle of attack required. In the end resorted to long handled adjustable spanner with an articulated head. Not sure what they are called. Tightening this nut down properly is a chore and not surprised that I missed doing it properly on shock jnstall.
Good luck. If I can find the original shocks today in my shed I'll measure the nut for you but you are going to need a particular type of spanner. As you will know the shock is at a tricky angle to the access slot and keeping sufficient contact pressure on the nut to tighten adequately is the trick.
I don't remember what size it was when I changed the shocks to the ome setup. What we did was get it on a lift. Removed the tire and stuck in spanners till we got the right one. I've got a basic tool kit in the back of the 200 and tried to fit the largest spanner (17) and it was too small and just barely got it there on my fingertips
Ok...so basically you got some different sockets and tried them out.... EXACTLY what I said.....![]()
Once you confirm the size something like this would be handy to buy and keep in the tool box for next time.
Articulated ratchet spanner:
No. Move on.
22mm socket
