Rear Passenger Side Water Leak
Central Virginia
Greetings. I have a leak somewhere on the rear passenger side. I am getting standing water in the two storage boxes in the cargo panel on that side. I have looked all over and cannot seem to track it down. Any thoughts?
Sounds like either sunroof rear drain clog or roof rack bolt loose. Search for either of those on here. You can use something semi rigid but soft enough to make turns like weed-eater cord to snake through if it's the sunroof. If it's the rack, tighten the mounting screws and use some type of silicone to seal em up
Sent from my iPad
I had a similar leak from the rear wing window not closing tightly enough to form a seal with the gasket. Check and see if that window is loose.
... Or if you want to go cheap and don't use that window you could do what the previous owner of my LC did and tightly twist some steel wire around the extension arm to tighten the seal with the gasket.
