I last replaced the rear pads on my 97 CE about 18 months ago, then installed 100 series pads in the front 6 months later. Last week, I started hearing the tell-tale squeal from the rear - sure enough, the pads are already toast. I checked the fronts while I was at it, and they're still at about 75%. What could be causing the rears to wear faster than the fronts? Vehicle is not lifted, and I go easy on the brakes. Any ideas?
Ping Scamper - I found this post about your 97 CE with the exact same problem:
https://forum.ih8mud.com/showthread.php?t=1775&highlight=rotors
Did you ever find the cause of the problem?
Oh, and CDan - you have a PM regarding some new rotors!
Cheers,
Brandon
Cheers,
Brandon
